Kart For Son
bexdee
Melbourne, Australia
Hey all, first time poster here looking for some help.
I am looking at making a kart for my son (he is 15.)
I recently purchased a pocked quad bike which im hoping to use for parts as engine does not work. I am abit stumped when it comes to the engine i should purchase.
I have come across this:
4 stroke (air cooled)
196cc
Max Power Output: 6.5HP/3600rpm
Rated Power: 5.2HP
Max Torque: 13N.m/2600rpm
Compression Ratio: 8:5:1
Dimension (L*W*H): 400 × 345 × 380mm
Net Weight: 16KG
This engine is horizontal shaft and wondering if this will work? And what sort of speed we might get out of it? I will (hopefully) also be able to ride this and i weigh roughly 205lbs.
Will mostly be used on grass.
Thanks in advance.
I can't tell you why no one has replied to this thread (slack a$$es) but I can tell you that the engine you're considering is close to what just about everyone here uses, sounds like a Honda GX 200 or clone...
Just about everyone in the US uses the Harbor Freight 212cc Predator engine which can be bought for around $100 but, without knowing your location, I'm not sure whether that's relavent to you (hint, fill in your location in your profile ;))
If you make a small enough kart you can use some parts from the quad but, not many; the axle isn't very long so, it would be a narrow kart (or, at least, the rear end will be...) which means the kart will need to be short to compensate... maybe too short for a teenager...
Having said that, the rear end of my 110cc chinese quad bike is narrower than the front end by around 6-8" so, I can't see why you would have a problem... the steering would need a lot of work though...
bexdee
Thanks for the reply Fabroman,
I didn't think it was that bad of a question causing no replies lol, considering i know little about go-karts. For the record i am located in Melbourne, Australia.
I do believe this motor is a clone of the Honda. So putting everything else aside, it is safe to say that this motor will work, and work efficiently hauling my a** around? haha! Can i expect a good speed? and enough power to pull me up a slight incline of grass?
Again, thanks for your reply :cheers2:
That LITERALLY makes a world of difference...
It certainly sounds like a clone; let me guess, it's around $125?
That depends on what's between the engine & the axle sprocket; if you use a centrifugal clutch, top speed & hill climbing will be limited; if you use a more expensive torque converter, those issues go away...
For a TC, contact Mike at Star Products; they have other parts but, only a small range; for anything else try Paul at Cut Price Racing (he's a member here); he's a little more expensive but has a wider range...
