Kart Engines
yes or no
  • yes
    Votes: 8 80.0%
  • no
    Votes: 2 20.0%
  • Total voters
    10
South Kart3377
Kart designer
Va
Alright who else here thinks the EPA should let us have a Karting Package for Engines (Open pipe, K&N Air Filter, Easy Thottle Linkage and Clutch.) Vote you views on this thread's poll.
r_chez_08
Should be in the shop...
Cornwall, UK
Why are you trying to get the EPA sued? All they are trying to do is burn less gas! Unless there is actually something stopping you from installing all the goodies on your kart.
And why do you want a flat head? Sure they are cool, but the ohv and ohc designs are far superior.
Thats like saying, I am going to sue because VW no longer make their campervans!
South Kart3377
Kart designer
Va
Sued, not anymore, I lost my head again sorry. But making my briggs OHV kart engine come with high back pressure dosen't solve any of these problems. And the Raptor was phased out due to EPA Regulations. I am not sueing briggs they didn't make the choice.
kendelrk
redneck engineer
westland michigan
they are still out there. who says you cant find a Milwaukee drill instead of a royobi? or find a raptor 3 instead of a clone? parts are still available
South Kart3377
Kart designer
Va
There are a lot of things I miss, that you can't get new anymore. Life's like that. So... Source an old one, and restore it!
Me too.
Yea, and I have a raptor 3 with I-Beam Billet Rod, Billet Flywheel and a 28mm Tilly Carb, It's dyn'd at 41.5 HP at 6,000 RPM Top end is 10,000. I drove a friends 72' Camaro with twin carbs and a 6.6 liter, Thats a FAST car. As far as Products I'm livin' in 1984. I need some shut eye now. bye bye
bighead
Pacific Northwest USA
If the left wing tree huggers get any more love we will only have electric karts in 10 years. All they have to do is convince you it's for the better of the people.
I wonder what an F350 will look like with Obams's 55mpg regulation by 2025? Or the Corvette for that matter. No big deal right? I like when I have no choices but a Chevy Volt.
B man
Tecumseh FTW!
Oliver springs,Tn
Ha we all know that regulation will never happen:roflol:
South Kart3377
Kart designer
Va
Epa
Look what I just found
Can I make adjustments to the new engines at home?
Consumers should perform routine use and care maintenance
as recommended in the operator’s manual. However,
owners should contact a qualified engine technician
for adjustments not listed in the operator’s manual.
Owners should also be aware that it is against the law to
tamper with an EPA-certified small engine. Tampering
with a certified engine may involve adjusting the fuel or
exhaust system, or changing the engine’s performance so
that it no longer meets the manufacturer’s specifications.
Tampering may increase an engine’s exhaust emissions,
contributing to our air pollution problems. To stop customers
and repair facilities from tampering, manufacturers
have equipped many engines with special caps or plugs
that limit or prevent adjusting the fuel mixture or engine
timing. Removal of these special caps or plugs and
adjustments beyond the manufacturers specified limits are
considered tampering and may subject the violator to a
fine.
Here's the site http://www.epa.gov/otaq/consumer/f98025a.pdf second page.
matman55
I dont have a camera!!
Mims FL
wow,the epa thinks they can tell US what to do?good luck with that. the earth is not going to end just because i want to upgrade my small engine.the earth is pretty **** resilient and it can handle anything we dish out.
Look what I just found Quote[Can I make adjustments to the new engines at home?
fine.]Quote Here's the site http://www.epa.gov/otaq/consumer/f98025a.pdf second page.
Normally, I consider myself a good law-abiding citizen. With this one? Get bent. Find me. I'll adjust what I want, when I want. Tough ta-ta's.:furious2:
r_chez_08
Cornwall, UK
Ah now I understand. Well they can screw that!
Reccon it applies to my gx160 in the UK with an EPA sticker and a straight pipe? Oops too late :p come and stop me.
That's why loads of these carbs have those f'ing annoying caps over the idle mixture screw. Ergh.
Now I understand why you are a bit pissed off. C'mon EPA, putting a straight pipe on a kart is the least of our worries!
South Kart3377
Kart designer
Va
YEP!
I will quote that when I sue them.
Now every body knows why I dislike the EPA, and D@mn laws.
