anderkart
I'll have to check. Running back to my house today. But I know they have that "L" bracket. Not too sure if they have that entire top bar howeverY
And it's not so much bubbles as much as the entire line fills with air.
That's ok, doesn't matter if your nerfbars have a top bar or not. I just wanted to make sure they had pod mounting brackets, because some don't.
The connections in your fuel line from the tank to the pulse pump are probably sucking in air. Try installing new fuel lines, (if they're old and hard) and be sure to use small wire ties as hose clamps at each of your connections to insure a good seal
That's what i was thinking. Disconnected all the fuel lines when I got the Kart to drain the disgusting fuel that was in the tank. And the lines are alright but could still definetly be replaced.
