oxyjansen
Hi, I recently acquired a Kango electric kart that I plan to convert to a live axle, larger tractor turf tires, and a Kohler 18hp Magnum twin with a Comet 44/40 torque converter. The finish product is to be for 1 adult rider.
Steering needs to be reconfigured, steering shaft beefed up and moved to the center of the kart, spindles moved outwards to accommodate wider tires, and turning, etc.
I'm sure many of you will notice that the right spindle arm is bent. I have 1"id tubing to sleeve them once straightened to add some strength to the front end.
Questions:
Should I set up for KPI and Camber, or does it matter much with an offroad kart? If so, what are the best angles in degrees to use?
KartFab mentioned to me that the steering arms on the spindles should be 2x the length of the pitman arm. I assume I will either need to replace my spindles, lengthen the steering arms, or completely rebuild them if KPI, etc. is to be built in?
I've not read too deeply into Ackerman, but it seems it might also be an improvement?
Are Dingo spindles with springs worth using?
Suggestions of mods to strengthen the rear end for 18hp are most welcome. The kart is actually built quite well, and more heavy duty than I expected.
Thank you!
Questions:
Thank you!
