just wondering????? axle problem
jafet valid
Houston
hi guys,
Ive really came to a reallly confusing stage of building my go cart.
I want to know if you could make a axle with 3/4 dia. hollow steel tubing.
The reason for this is because my wheel have 3/4 inch hubs and I cant find a axle for this.
P.S is welding on the axle a good thing?
Just use a 3/4 keyed shaft. Now if its a stepped shaft you will have to go off of the original.
Do the hubs have a keyway present?
No, 3/4" hollow tube will twist very easily, add the fact that, once you cut a keyway into it, it will than be open. 3/4" solid bar is ok for a low powered kart but, follow chris' advice, find some 1" hubs...
