Just got a 8hp Tecumseh used
Fun from Boredom
Alabama Dallas county
Got from a close friend who said he had got it when a friend died and he has never looked at it so doesn't know what us wrong with it or anything. Just a little messing found the carb is stuck closed here are some pics IMG_20160108_135113.jpg
Kokamo
Azzkicker extraordinaire
Liberty Hill, Tx
Nice! If that carb is stuck, I recommend getting a new one. Those carbs are finicky as all heck. Part number 640125 and pretty cheap HERE.
Also if it helps, HERE is a parts breakdown.
Good luck!
~Joe
Fun from Boredom
Been working on engine and rebuilt the carb and cleaned the engine up like new and redid fuel line put fuel filter and petcock on line. Only problem is when I cleaned it all up I started it and it ran for a minute and when I reved it up it died had sand in carb . cleaned tank filtered the fuel and cleaned carb again it started then died and again more sand in bowl . I think it is under the cap for the machined section of the carb got to pop plug out and check . I'm getting there but it is sure being a pain. Will keep y'all updated take care.
2SlickNick
American Minibikes @ FB
Mesa, AZ.
That is a nice engine. I have an 8 hp Tecumseh engine that runs on my mud bug three wheeler
These flathead engines can be made into some mean engines. I have remove the governor on my 8 hp
---------- Post added at 12:58 AM ---------- Previous post was at 12:57 AM ----------
Could you do me a favor and measure the bolt pattern please? My 8 hp Tecumseh uses the smaller boat pattern I was curious if these newer 8 hp Tecumseh use the same pattern. I was going to buy one from someone in our way.
