Just did a governor removal predator 212, question about the pull start
When I pull the rope it has resistance, let's up then has resistance again, but after that the whole rest of the way is free just a little more difficult to pull but not much, want to make sure if this is normal or not
Staff Murderator
Are you saying the engine has more resistance than it did before you opened it up?
You didn't touch anything else while you were inside the crankcase, did you?
You're supposed to have some resistance--that's natural compression.
Are you pulling the rope fast or slow?
I didn't touch anything else, iirc it has just a tad more resistance but the last time I pulled it was about a month ago, I pulled it slow just to make sure it wouldn't get stuck or anything and I wanted to make sure the extra catch(?) wasn't gonna be an issue before I actually start it
---------- Post added at 01:19 PM ---------- Previous post was at 12:51 PM ----------
I'm pulling it slow just so I don't break anything by pulling it fast, iirc there's just slightly more resistance now than there used to be
Staff Murderator
Truth be told, the compression release is centrifugal on these engines, so the starter rope needs to be pulled hard (as if you were trying to start it) for it to feel normal.
EDIT--there's a weighted arm and linkage on the camshaft that acts to prevent the exhaust valve from fully seating, then the compression pressure from the compression stroke leaks out through the partially open exhaust valve. This allows the piston to easily move past Top-Dead-Center and into the correct position for easy starting.
