Will
So I was thinking about torque converters
I had an idea of a tc (with a jack shaft built into it) and instead of it driving a sprocket onto your axle, it attaching onto ANOTHER torque conveter, but instead, the spring that engages it is changed so it is constantly engaged, the second tc would drive the chain to the axle.
So two tc's, first drives the second (which is always engaged) and the second tc drives the sprocket which is attached to the axle.
I understand how there is a 10% overdrive so that would become a 20% overdrive.
I understand tc are expensive but buying 2 cheaper clone ones and testing it out might be a cool idea,
I thought that tc gives u a wider range than a fixed gear
So two torque converters would give a even wider range for the engine (by range I mean like how the ratio changes)
Let me know what you guys think ?
Cheers
Cheers
