Junk yard build
Charliekelly77
So I'm trying to build a mini bike from some junk I have in my garage. I got the bike and this what I believe is a Tecumseh engine from the 80's. I've got the design kinda down. I'm a little concerned about the flywheel since it used the blade for momentum. I'm not trying to buy a lot of parts but I am buying a centrifugal clutch. Will that be enough weight or am I going to have a problem in between strokes. I'm a novice so if you have any heads up info for me, I'd much appreciate it.
Ebrownie
Western Montana
Welcome to the forum! Unfortunately, I can not help you very much without pics of what you have. Get some pictures up and we should be able to give better advice :thumbsup:
Charliekelly77
I'll try and get some pics up. But I know it's an aluminum flywheel. My question is Will the clutch and resistance be enough to balance or will it just back fire and stall.
Charliekelly77
Pics
karl
North east Ohio
That is not good minibike motor. Shaft size, mounting, carb issues, oiling issues, no good.get a proper horizontal shaft
Charliekelly77
Hahaha. I know I'm saving up for a proper build. But I did already make a mounting plate, a plate to turn the carb, and I added a l bracket to the bottom of the crank (the governor looks like it should sling some oil too. ) Do you think I need anything else to get going. What's the problem with the shaft
