screamnfly
- Messages
- 6
- Reaction score
- 0
Hello all!
My name's Justin, I'm fairly new to the karting world. I first had a small home made kart with a 5home Briggs on it. T. I went to school to fix jetskis, and my dad's best friend James builds shifter karts in Ocala Florida. So I have a GP800 engine in my shed out of a 2001 Yamaha GP800. It's a 2 cylinder 2 stroke with 84mm wiseco pistons, billet aluminum high compression head, big bore carbs with the chokes removed and filled in, after market flame arrestees similar to k&n, and carbon fiber reeds for immediate throttle response. I got this out of a blown up jet ski and want to put it on a kart. The ski would do about 62-65mph so I'm thinking with the right gearing it should scream. I work for a metal fab company and will build the frame, and laser out any brackets needed, motor mounts, etc. Then machine a solid axle with keyways for the brake rotor and driven gear instead of set screws. I can't find anyone who has done something like this so if anyone knows why or has tried let me know. The hard part is the cooling system because its not closed and sucks up lake water then meets the gasses in the exhaust manifold and stays with it out the pipe. But this engine has a big water box. So I'm going to put baffles in the pipe after the water box in a tube going straight up. And run a bilge pump to cycle the water out of the water box (or muffler) to a radiator with a fan, then back into the head again. There's more than enough power in the stator and wouldn't put a load on the motor. Any ideas are appreciated. Can't wait to learn from you guys. Later.
please use the EDIT button in the lower right corner of your posts to add to them, instead of multiple posts only a minute or 2 apart.....
