danssoslow
If I got long enough hardware, couldnt I run a spacer to achieve the same thing? like a bolt sleeve?
To create a 15* mount? I'm not sure that would be safe; with a joint in the rear, longer mount. Not just that; but if the mount doesn't have an actual top plate that the risers attatch to, those risers alone then become a structural part of the engine; as the mounts are linked to them. Know that, the you were to make an extension on the rear riser, and it was able to flex at all, that is going to stress the engine block's rear mounts, as possibly crack your block.
