jamilcobra
Hello. I need some advice on a torque converter. My kart is set up with a 10 tooth arena clutch with a 70 sprocket. It is used in parades so its wide open for 30 yards or so then hit the brakes, turn and repeat. The 7.0 gear is perfect for what we do, but it is hard on equipment. I generally get about 3 or 4 runs before the clutch bearing needs to be replaced, and the clutch hangs off the crankshaft which is surely putting extra stress on the crank. With this in mind I am trying to decide between a jackshaft or torque converter. I understand how each works, but I am curious about the durabilty of a torque converter. Can it handle constant starts over and over, and will it pull as hard as a cetrifugal clutch? Also will the belt take the abuse? The engine is a stock yellow clone with a bored carb, no governor. Just guessing but it is probablly turning around 4000max during parades. Thanks guys.
