Jackshaft gearing, what do you think?
Clayton
Saskatchewan, Canada
Okay, I am building a kart and am planning to run a jackshaft. I am gonna be running a clutch on the engine that has a 10tooth sprocket, that then goes to a 15tooth sprocket to give me torque, that is on a shaft with a 10tooth that then goes to the 54tooth on the rear wheel. I know it may sound confuzing. But would you think it would work? Any suggestions for imporvements would help. Thanks. :auto:
Without knowing more details, I can't comment. Your overall reduction ratio works out to 8.1:1.
Need to know approximate weight of kart and driver,engine size, intended use, and measured rear tire diameter.
Clayton
Sorry, I should've realized that, the weight of the kart with me in it would be 250-300lbs, the rear wheel height is 15'', the engine will be atleast a 5hp(don't have yet) but probly a briggs with no governer. And it will be used for all on road use, it will be on really packed gravel (I will be drifting it around).
Uhh, Herman- threadjacking is considered, well, inconsiderate. Start a thread to ask your own questions, you'll get better results. Thanks, and welcome to the forum.
