Jackshaft/Gearing/Ratio HELLPPP
island
Guam U.S.A
Guam U.S.A
Hi guys, I need all you gokart veteran advice, I am very new to gokarts and been reading some thread and found this one on here http://www.diygokarts.com/vb/showthread.php?t=14190 I think i will have a similer problem with my gokart project with over heating the clutch:worried2: I just purchase a 10tooth clutch and it will be connected to a 40tooth axle sproket I need to know if this will work with out any problems? Also if i was gonna go with a jackshaft what would be the benefits and best in and out jackshaft sprokets tooth count? One more thing need help in the ratio calculations don't know anything about ratios. All advice will be greatly appreciated
We need more information than you have given us. While it's a sure bet that your current reduction ratio of 4:1 is too high, we can't fine tune it without more detail. Measure the full height of your rear tire from the ground to the top of the tread, and provide us with that number. Give us your engine type and HP rating, and a good clear description of the kart- We need to get an idea how heavy it is, and what the realistic capabilities might be. Also tell us your intended driving conditions are- flat track/asphalt? Dirt or gravel? Hills? Dunes?
island
Guam U.S.A
Guam U.S.A
This is the kart, tire and motor which still has the governor. The clutch is a 1" bore 10tooth the axle is a 1"bore 40tooth with #40/41 chain. I don't mind 25mph or less its just for slow trailing with my daughters. May i add this is a budget build i have many metal scraps that i can fabricate and the weight is 300lbs or less including the kart. My main concern with It if i will have any issues with it like the over heating with the engine and clutch. :worried2: All advice are welcome and will be greatly appreciated. Thank you very much
Tire is a 14" top to bottom, Engine is a GX390 don't know were to find the RPM? We will be riding on road, some hills and grass.
[/IMG]
[/IMG]
[/IMG]
island
Guam U.S.A
Guam U.S.A
Thanks ordering the 60t now, I found a 47tooth lying around and im sure i have some more sprokets in a box somewere if i can find it:mad2: Thanks again:thumbsup:
