Jack Shaft Help??
Jsmith813
Im building a go kart with a YTZ250 2 stroke engine. I want it to have good acceleration with a fastt Top speed. I have 16in tires.an the drive sprocket is a 15Tooth but can be changed if needed. Please help I was kinda thinkn of using to jack shaft set ups to have a real good top end an good acceleration. Im not sure what size i need sprockets i should use Reply soon Thanks:auto:
Using a sprocket that's similar in size to the original bike is usually the way to go. Even with the smaller tyres, you should get pretty good acceleration & a decent top speed.
Why use a jackshaft?
BTW: Your (so far) other post was a bit pointless; that thread is 3 years old. It's extremely unlikely you'll get a response. Good on you for searching but, choose carefully.
Oh, & :welcome2: to the forum
denhammotors
Stuart, Florida
Please help I was kinda thinkn of using to jack shaft set ups to have a real good top end an good acceleration:auto:
A jackshaft will not give you good acceleration and high top end. You would have good low end torque with a jackshaft, but for high top speed, I would just stick with the bike's original gearing.
Jsmith813
Yeah
Well stock gearing is 13/42...with 22 in tires... i just dont thnk it will have much speed.. :/:ack2:
denhammotors
Stuart, Florida
According to our speed calculator, you'll get 85mph @ 5000rpm (which is mild for a 2 stroke) using 16" tyres & 15/42 gearing. Is that not fast enough?
Remember, 5000 rpm at the crankshaft will almost certainly be faster than at the countershaft sprocket on a motorcycle. To properly calculate the top speed, one must know the primary drive ratio and all of the transmission ratios (assuming this engine does have a gearbox). The front sprocket RPM is usually about 1/3 of the crankshaft's.
Jsmith813
Ohh
Could anyone look it up for me?? I cant find it... Its a 1986 Yamaha Tri Z 250... An Those Calculations Dont Include weight an friction into the situation. But I thank you all for helping :wai:
I found a service manual HERE. I wasn't going to download it to have a look, but I am sure it would have ratios in there.
I just googled "Yamaha Tri Z 250 manual". I got several hits you might look at yourself
denhammotors
Stuart, Florida
Found it
Primary reduction ratio- 2.625:1
Secondary reduction ratio- 3.384:1
1st gear- 2.384:1
2nd gear- 1.75:1
3rd gear- 1.411:1
4th gear- 1.142:1
5th gear- 0.956:1
