There are 2 CdI configurations.
What you have is an 'open to run' CDI. This means that grounding lug should
not be grounded to produce spark.
I have run into some non operating
L-B CDI's and the following is what works 80%
of the time.
Pre-heat toaster oven (
not microwave) to 200° F max, and bake CDI for 2 hours.
When finished baking, drop CDI (while hot) into coffee can filled with enough WD-40 to completely cover CDI.
Gallon cans of WD-40 available at Home Depot and Lowe's.
Let sit in WD-40 until cool (about 15 minutes).
Reason for WD-40 is it's ability to drive out moisture which is #1 reason why L-B CDI packs fail.
2 reasons for baking:
1.) Drives out moisture.
2.) Heating causes everything to expand allowing WD-40 to 'suck in' to areas as CDI cools (contracts).
As I stated, this works most of the time but not all the time.
This is a cheap fix as CDI packs can cost between $30 ~ $60.
Don't forget to set gap at .010 inch using a feeler gauge.
Torque to spec, 25 in.lbs. max.
Use of torque wrench and correct feeler gauge cannot be over emphasized.
4.5 HP and 127cc's or 7.75 cu. in.
