It was running a minute ago....
BAM
Accelerate, turn, crash
Georgia, USA
I just purchased a used minibike. The engine started up just fine. I disconnected lights and whatnot and BOOM the engine doesn't start. I think its CDI but I'm not positive. Please help! :confused:
BAM
Georgia, USA
No 2 wires are the same color. I realize this afterwords, there's no telling what connection went were. :oops:
kartingizm
Murray Hardrive Gokart
maybe the kill switch got disconnected or the lights where connected to it?
Badot
Yeah, with pulling wires I'd think something with the kill switch/ignition system went screwy. Easiest way to check (if you mixed up the wires) would be to pull the plug and check to see if it sparks fine.
I just can't think of any way the kill switch could/should/would be connected to the lights...
BAM
Georgia, USA
I think I got it solved. I'll check to see if the plug is sparking (just wrench it out and pull the starter cord and see if it sparks?) but I think it's my fuel. I believe it's a 2 stroke engine and I forgot to pre-mix oil. Oops...
Bluethunder3320
it would run regardless if you have oil mixed in the gas.
but running it with straight gas, after about a minute, it would seise or overheat...
make sure when you check spark that the threaded part of the spark plug is touching somewhere on the engine block, or else it wont work.
BAM
Georgia, USA
The spark plug sparks, I checked it this morning by wrapping a wire around the threaded part of the spark plug then running that wire down to the ground wire. I pulled the starter and it sparked. I cleaned out the carb (I think. I unscrewed the primer bulb and gas came out). The new 32:1 mixture is in the gas tank, I can see it in the gas lines as well. I pushed the primer bulb twice and tried to crank it up by pulling the starter cord 5 times. Nothing happened.... Still dont know what is wrong. Any other suggestions???
