R
rIchard taeger
Guest
hey I just got a bristers thunderkart( slxl-700) running after sitting for 17 years.i changed the tank as the rust in it was clogging the fuel filter.i also rebuilt the carb.it ideals great and runs well.till you put a load on it. I ran it in a cut field for about 10 minutes and it ran about 20 miles an hour,then the motor just died,but it started right back up,but still would not run under a load. I must say I weight 265,but the kart still ran with my big butt on it those 10 minutes.
the other problems are the chain is somewhat loose but not coming off and the max torque clutch is the original 17 years old.
any way I rode it yesterday and it ran with my big *** on it,i hit some grass that was 5 to 6 inches tall and it acted like it was bogging down then it died again and the clutch was smoking.
it started back up and I put it away to let it cool down. any way hope I can get some feed back on this? would changing the clutch and tighting the chain solve this problem as I think with my weight plus the chain and clutch problem iam putting to much strees on the briggs& Stratton engind causing it to die any thoughts besides me loosing weight would be very helpful the motor is a 5 hp. thanks to any one that can help. iam trying to get running for my grandson,i will not be riding it just doing it now to get running.
