Issue with throttle
freakincage
Winnipeg, MB, Canada
I posted this in my build thread, but maybe I'll get more info here. I don't know a lot about jet sizes, and things of the like.
The engine is running a custom intake and exhaust made from 3/4" black pipe, regular small engine muffler and a offshore carb for a 110cc and whatever else engine. I thought I would have to rejet, but after playing with the mixture and idle screws running it at 3400 rpm for a few minutes and pulling the plug, it all looks good. Sorry no pic of that. The throttle is weird though. When I push the gas to where I have the stop set, it revs to about 2100 and then slowly "accelerates" to 3400. Any Ideas as to why?
freakincage
It doesn't seem to bog, but I haven't had it under real load yet. I did a bit of searching and found a manual for briggs racing carbs. It says that the animal, 206 and m-series engines use a PZ-22 carb. I believe the one I have is a PZ-19, made for offshore stuff up to 125cc. I also found out what jet sizes the pz-22 is to use. I'm now going to check my jet sizes and also check for vacuum leaks. This is the guide I found.http://www.briggsandstratton.com/engines-racing/~/media/Racing/carbtuningguide.pdf
firemanjim
Just kartin' around....
Houston Texas
The pz19 is a good performance swap, with no need to alter the fuel circuit..... It's fine the way it is, that's why people swap to those versus nodding a stock carb....
The problem might be that you are flooding that carb because your tank is tooo high above center. You are most likely stumbling on fuel load-up on take off , then fuel is consumed at a faster rate than flow from tank, so it progressively gains speed..... ?
freakincage
Thanks for the input, but I don't think it's flooding. The fuel tank is about 5" above the carb.
Now that I have my torque converter issue sorted, I can go for a little test boot. I'm not 100% sure I have a pz19...it might be a pz17. Is there an easy way to tell the difference? I dug this out of a bone box at my local outdoor power sports place because it was faulty. The fault was a leak from the float bowl and the remedy was tightening the screws. I sized it by getting the carb that had the closest size bore to match the intake hole of 3/4".
firemanjim
Houston Texas
I just got home, give me a few and ill go measure the bore on my pz19's and see what they are. I think the 125cc engine I just bought is a pz20 or pz21( whatever the next size is, as it looks a lil bigger that the one on my 110 or the 2 spares I have in my tool box.
I think I'm gonna put one on a 3.5hp briggs engine and remove the vane governor. See what it runs like..... I'd be interested in making a video of a tec engine blowing up at full rpm..... BUT I need like 4 or 5 go pros to do it right, so...... Maybe another day.... I have the perfect engine to blow up too... :stir:
freakincage
Also the reason I swapped out the tank is because the carb was physically damaged beyond repair. There's a thread about it in this section. Briggs carb swap and keep governor or something like that.
freakincage
Little gnomes must have come and fixed my problem, if in fact there ever was one. Once I took it for a test drive there was no problem. Throttle is working fine. I do wonder why it acted weird when it was just the engine by itself.
firemanjim
Houston Texas
Ok, well I was fixing to post some pics. The pz19 bore is .735 and the venturi opening is 1.290 and just as a comparison.... My 125 has a pz26 and it's venturi side is 1.380 but I was too lazy to remove it to check bore size..... :lolgoku:
Glad your ride is running right, now....... :thumbsup:
