Is this worth rebuilding /fixing?
jd0401
Commerce City, CO
Hey guys,
I acquired this go kart a couple weeks ago and the engine is bad (i have a 301 cc predator i could use) is it possible to add shocks to this somehow? And what eould you guys recomend for reinforcing the frame for an engine this size ?
KartFab
Dallas, TX
Manco 485. Yes worth fixing. I fixed up two of those before Christmas. Both had bent roll cages, bent spindles, tie rods, broken frame, improperly rewelded spindle bracket. Got all that fixed up.
I used the 212cc predator it just bolts right in there. You can slide the motor mount plate back a bit too if you want to slide the seat all the way back (welding required).
KartFab
Dallas, TX
Majority from gopowersports with 10% off code (diygokarts)
Rest that I could get cheaper from other places on ebay. I made the seats custom.
jd0401
Commerce City, CO
Awesome i haven't gotten to the drive system yet so im not sure what it looks like or how its set up hopefully. The plan is to tear it down paint and im sure there are some welds that need to be done. I will post pics and what not when i come to it. My main concern is gettin the 301cc on it.
KartFab
Dallas, TX
Here is the torque converter set up. You will likely need to move that motor mount rearward so the seat doesn't hit the engine. The space is there, just gotta make it fit.
