is this worth 80euro ??
So, it's a package deal but, he's willing to sell you one? I think it's worth it if the engine runs! There are a lot of other parts that can be used.
Are you planning to just swap the heads or the whole engine? What's wrong with your head?
zip kart
ireland
ye after a long time talking to him he said hed sell it to me for 80e
im just going to use the head
the head on my quad has no treads spark plug wont tighten up fully
so the price is good then might see if he will take 70e
IIWM, I'd swap the whole engine; it's easier & cheaper. Pulling the head means a new head gasket & a bit of messing around which may result in problems. You're gonna spend the time anyway so, just swap out the whole engine
Try it but, don't push it :lolgoku:
zbuck
Ft. Wayne, IN
:wai: When I can not hear an engine start and run. The price I am willing to pay drops considerly. Since you have to pull the head on your engine, why not just install a thread restore kit.
zip kart
ireland
could i use the engine off the spare quad to rebuild the good quad
can i use the same gaskets for the head
It's never recommended to re-use any gasket, especially a head gasket.
Sometimes, you can get away with it, depending on the type of gasket
zip kart
ireland
could i rebuild the my quad engine using the other quad engine ?
and is it a big job to change the head
is it just a blot off swap and and bolt on job or is there more to it because i was going to get a mechanic to do it for me ?
zip kart
ireland
i was thinking of getting a mechanic to do it for me would i be better off
and can someone tell me
if the quad im getting for parts isnt running will that matter
as i only need the head ????
I figured it was about $100. Not a bad deal at all around here, but "value" is very regional. Might be a total ripoff in Ireland, and a steal in South Africa. Who knows?
But I agree. For somebody in Zipkart's position, it may be preferable to use parts off his existing engine to save this new engine- then put the whole thing into his existing quad.
zbuck
Ft. Wayne, IN
:wai: Have you actually checked over the new engine? The reason I am asking is, in your 1st post post you stated that the engine is not missing anything. Now its missing a carb., which leads me to wonder what else may be missing on that engine. I'd cut my offer to 40eu and take my chances.
If the quad was working, it would be an absolute steal here in SA
