zzirrgrizz
- Messages
- 35
- Reaction score
- 0
On the motorized bike I am building here are the gear specs:
Ratio: 4:1
Clutch- 11 teeth
Sprocket- 44 teeth
Rear wheel- 22"
RPM for engine- 3600
will this work out or this a bad gear ratio? Sorry I am very new and want to make sure I am doing this right. I assume it should be okay since a lot of motorized bike kits use this ratio but I just wanna make sure.
EDIT
I also have a 62 toothed sprocket as well that I could probably get to work, so let me know which one you would recommend I use
Ratio: 4:1
Clutch- 11 teeth
Sprocket- 44 teeth
Rear wheel- 22"
EDIT
