Is this a good torque converter?
NotSoMasterMind
South lyon michigan
I was looking for a 40 series torque converter and found this on amazon (link below) and was wondering if it is worth the money for me to get it. It was originally $200 and is now half off at just under $100.
CNCShop Torque Converter Comet Clutch Go Kart Clutch 40 Series 0.75 Inch Driven 1Inch Driver Clutch Pulley Set Kit Comet 40D (3/4" Driven 1" Driver Clutch) https://www.amazon.com/dp/B019SL0LUK/ref=cm_sw_r_cp_api_0pyCyb07FBRGK
B_Bimmer
I wouldn't put much stock in the original price when assigning value but based on the reviews it appears to be an acceptable 40 series knockoff.
minor complaints about the longevity of the chinese belts every now and then...
that's it.
and since you can replace a crappy belt with a quality one (as you can always do)
I don't see a problem at all in buying a 100 dollar series 40 kit.
KartFab
Dallas, TX
The Chinese belts for the 40 series torque converter have the proper width and outer circumference, but are thinner than the genuine comets. You get less surface area contacted on the drive and driven, so the belt slips easier.
Joe-405
Enjoying New Projects
U.S.A.
I would say that will work just fine. Just don't use a high rev engine or highly modded 420 with it. Mine was fine til I turned the timing up and ran it on full kill past 6000 rpms.
