Is there something missing?
solomon
ca
yup, thats a full fairing one you got. Its slightly more expensive. Do you have the stock carburetor on it? Also when you replace that flywheel i would order a "Rocket Key". its just an advanced timing flywheel key. Also keep in mind, those 47cc engines can be the hardest thing to start ever. Its the cheapest design ever!
KieranM
Doin It!!
Kilkenny, Ireland
Probally a lightened flywheel and a better carb. I havent started her up yet still few things to do. there is a list of things to do that i havent decided on yet.
solomon
ca
here is a list of BEST mods for the 47cc engines, LIGHTENED FLYWHEEL, RACING CARB,ROCKET KEY,BIG BORE KIT,RACING CLUTCH SPRINGS,AFTERMARKET EXHAUST. After you have it running, see what gearing you are using, if it has plenty of take off power get a 1TH larger clutch sprocket. Oh and nitrous, that's about all these engines can do!
KieranM
Doin It!!
Kilkenny, Ireland
Oh and nitrous,
Would the engine be able to handle nitrous? They are only Chinese, and not the best quality.
I am going to save up a bit of money and buy a stock engine and change carb to mukini or the like (if i can find one), get a 9fin lightened flywheel, performance clutch, 8 tooth clutch sprocket, new exhaust, widening and polishing ports, carbon fibre reeds, change all engine bolts.
I should have a nice engine after that, but it wont be for a while yet, have more projects to get through
solomon
ca
don't buy a BLUE reed, they are junk. Get a black Widow Reed. And They sure can do nitrous, lots of fun! No mikuni will fit this properly, here is an awesome carb for it HERE
