Is that normal?
vegiemite
Disclaimer: Go kart newbie here.
I have been refurbing a go kart someone gave to me after it stopped running. It's a fairly basic street kart with an older Briggs and Stratton 5hp motor connected to a torque converter drive system.
To get it running I had to overhaul the carb and replace a worn out diaphragm. I also replaced the throttle cable and lower throttle linkage as the original was kind of hacked together.
However, the kart seems to be slower (seat of the pants estimation) than it was before when my friend had it. I've adjusted the throttle linkage to ensure it's moving the full distance possible at the lower linkage area where the cable connects as per this type of set up: http://i96.photobucket.com/albums/l193/purplewindworm/Briggs/100_0725.jpg
So as far as I can tell the throttle is working properly however I noticed there is still about a half inch or so that the butterfly valve can be moved forward which when running at full depressed pedal (wide open throttle) gives it a significant boost of power/speed.
I think that this is the governor in action which is fair enough but should there be that much allowance on the butterfly valve or is the lower spring that pulls the butterfly valve back stretched out and not doing it's job properly?
If this is normal operation (and if I shouldn't mess with the butterfly valve operation) any other ideas where the power might be lost or what else I could adjust to see more speed from it? Would adjusting the idle control screw/rod help at all to top end speed?
I've seen the governor removal how-to but not sure I'm ready for that step yet so looking for other adjustments that may be possible.
Thanks for any suggestions and sorry if I've overlooked a number of posts on this. I found a few related posts but nothing that really help explain this aspect.
Jon
anderkart
Surprise Arizona USA
If you ran this test with the karts back tires blocked up off the ground, your findings there might be meaningless because the engine would rev up so quickly.
But when your actually riding the kart, (and the engine is under a load) a properly working governor should pull the carb wide open until approx 3600rpm where the governor would then back off the throttle as needed.
vegiemite
Ok, this is while riding the cart so engine under load.
Not sure what rpm it was topping out at but it definitely has quite a bit more if I manually open up the butterfly. I fiddled around with the spring at the lower end of the arm that comes up to the butterfly valve and bent it about a 1/8 inch shorter and now I am getting more top end speed and I guess more rpms. Not sure if it's now running at more than 3600 rpm when fully open. What is the risk if it were? Shorter engine life or bits going flying?
Thanks for the reply!
Jon
anderkart
I cant say how long your engine will hold up but lots of 5hp briggs karts have the governor system completely removed and last for years reving to 5000+ rpm. But limiting your super high rpm usage to shorter bursts like maybe 5 or 10 seconds and then slowing down for a bit would probably be a good idea to make it last longer.
vegiemite
Sounds good
Thank you for the advice. That makes sense. We had it out today for a couple of hours and it seems to be running fine as is. It's quick enough now to be fun and the next challenge is getting the right tires on it as we burned through quite a bit of tread on the cheap Harbor Freight knobbies I had put on, particularly the drive tire. Dropped the air pressure a lot and that seemed to slow it down / spread it over the whole tire width.
