Disclaimer: Go kart newbie here.
I have been refurbing a go kart someone gave to me after it stopped running. It's a fairly basic street kart with an older Briggs and Stratton 5hp motor connected to a torque converter drive system.
To get it running I had to overhaul the carb and replace a worn out diaphragm. I also replaced the throttle cable and lower throttle linkage as the original was kind of hacked together.
However, the kart seems to be slower (seat of the pants estimation) than it was before when my friend had it. I've adjusted the throttle linkage to ensure it's moving the full distance possible at the lower linkage area where the cable connects as per this type of set up: http://i96.photobucket.com/albums/l193/purplewindworm/Briggs/100_0725.jpg
So as far as I can tell the throttle is working properly however I noticed there is still about a half inch or so that the butterfly valve can be moved forward which when running at full depressed pedal (wide open throttle) gives it a significant boost of power/speed.
I think that this is the governor in action which is fair enough but should there be that much allowance on the butterfly valve or is the lower spring that pulls the butterfly valve back stretched out and not doing it's job properly?
If this is normal operation (and if I shouldn't mess with the butterfly valve operation) any other ideas where the power might be lost or what else I could adjust to see more speed from it? Would adjusting the idle control screw/rod help at all to top end speed?
I've seen the governor removal how-to but not sure I'm ready for that step yet so looking for other adjustments that may be possible.
Thanks for any suggestions and sorry if I've overlooked a number of posts on this. I found a few related posts but nothing that really help explain this aspect.
Jon
Jon
