Is my clutch fine?
royjr
New York City
After installing a pedal to my 6.5 hp greyhound engine, once I start the engine on, and fully close/open the choke engaging the engine, the go kart speeds up with a lot of force even though I have a clutch on the shaft of the engine. In the begining of the project, we were running the engine on extreamly low speeds with on and off throttle pulls, which made the clutch smoke. After figuring out that you need to fully engage the clutch for it not to smoke, we were good. Up until the throttle was setup.
Possible reasons:
1. Clutch burned out (all of a sudden??)
2. the throttle is not set at idle at first?
Do you guys have any suggestions? im thinking about buying another clutch as a backup. Is there any alternatives to a clutch?
I use a Max-Torque clutch.
The project is set due on Monday, and I'm running out of time.. =|
once I start the engine on, and fully slide the clutch engaging the engine, the go kart speeds up with a lot of force even though I have a clutch on the shaft of the engine.
I'm sorry... What? I can't make sense of this. Slide the clutch? Lot of force even though the clutch is on the shaft? I need a clearer explanation of the issue. Pics may help, or may not.
Okay, step one. Take the chain off, and make sure the engine is doing what it's supposed to- being idling nicely at 1200-1400RPM when you open the choke.
royjr
New York City
so in technicality, I should be able to hold the clutches outside drum while the engine is idling, right?
And if that doesnt work, then either the engine is not on idle (somehow pulled by the new throttle) OR that means that the clutch is burned out?
Do NOT grab that drum!!! With no load- even at idle- it will turn. I'm just asking you to verify that the engine sits at idle. Check your throttle linkage- it's beginning to sound like it's too tight, not allowing the engine to idle down.
If the clutch is engaged, it's not burned out. Sounds to me like your throttle cable isn't adjusted properly; disconnect it & see what happens
I must beg to differ on this. When a clutch succumbs to excess heat, the spring(s) lose their tension. When THAT happens, the shoes will engage waaay too early.
That said, I'm staying with the throttle thing, too.
royjr
New York City
yey!!, I disconnect the throttle and chain hookup and tested it, the clutch works fine. was even able to stop the clutch drum with my hand. so the clutch was fine thankfully.
Turned out the spring setup for the throttle linkage was a bit of a mess. We used rubber bands and they were stretching around the gas tank. I turned out that it was holding the inner throttle links in the engine which was holding the throttle in the highest speed which is why when I opened the choke the kart just jumped. When I came home, I noticed that when the wheel went over my leg, it ripped the pants. =D lol. I fixed it today, just had to move the rubberbands away from the inner workings of the engine.
Thanks alot guys for your great help!
royjr
New York City
yea agree with that, but not on my mind yet, got to paint, fix chair, oil gears and finalize everything before showcasing the school engineering project on monday =)
