royjr
After installing a pedal to my 6.5 hp greyhound engine, once I start the engine on, and fully close/open the choke engaging the engine, the go kart speeds up with a lot of force even though I have a clutch on the shaft of the engine. In the begining of the project, we were running the engine on extreamly low speeds with on and off throttle pulls, which made the clutch smoke. After figuring out that you need to fully engage the clutch for it not to smoke, we were good. Up until the throttle was setup.
Possible reasons:
1. Clutch burned out (all of a sudden??)
2. the throttle is not set at idle at first?
Do you guys have any suggestions? im thinking about buying another clutch as a backup. Is there any alternatives to a clutch?
I use a Max-Torque clutch.
The project is set due on Monday, and I'm running out of time.. =|
Possible reasons:
