I have a Tech 4 Hp on my son’s mini bike. We can get it started no problem. When he sits on it and gives it the gas to move it will start to move slowly than a grinding noise and the motor stalls. If I give it the gas with no weight on it (lift up the rear wheel), it seems to keep running. Is it just a bad clutch? I removed the clutch and the inside hole opening looks to be about 3/4 diameter and has 10 teeth. The brand is Max torque. Is there any parts shops in Nassau County long island where I can get the part local?
