pRoFiT
Can't buy it?, build it!
Was posting on another thread about the HF 170amp welder plugging into the Dryer outlet and got this response.
Hmm, that's the first i've heard of that. I will investigate more. Currently i only weld with low settings. That 170 is powerful! no need to go anymore then the lower two settings so far. My dryer is running off two 30amp breakers @220V. i made a welder to dryer adapter using Dryer wire and welder receptacle.
Pictures of what i used to make my adapter.
anyone have thoughts on this? all welding sites show the same thing for connecting to a dryer outlet. Only concerns i've seen is on wire AWG being less then #14 so it doesn't melt
I will simply say DO NOT weld from your dryer outlet, unless you like the probability of starting a fire in your walls
