A arms in the front, be it single or dual. Singles are simple to make but, have constant camber changes, but can be remided with camber built in. Dual a arms are a bit of a pain to make, more geometry needed, but are a set up and leave it type, tend to get more travel vs single.
Could also do a trailing or I believe J-arm similar to Honda Odyssey or Trx 4 wheelers.
Rear end can be trailing, a arm, or swing arm. Trailing arms can be done with using 3 chains, one from the clutch/cvt to a jackshaft, then a chain to each wheel, will require several sprockets and you may want to run dual rear brakes.
A arms will require a custom spool, which needs a hub for U-joints or cv axles, 2 pillow block bearings, a short shaft to mount the hubs brake and sprocket.
Last one is swing arm. Now you can build one with the engine mounted on it, or move the engine to the side so it's sprocket lines up with the pivot point so you don't have to worry about constant chain tension issues. Best example of such a setup is the Edge Sidewinder.
More than one way to skin a cat. Independent all the way around will give a more comfortable ride, but a bit more work involved.
