ryf
- Messages
- 309
- Reaction score
- 0
I am adding rear suspension to my mini buggy. I am wanting IRS, but a single swingarm would be SOO much easier... looking for ideas as I have some but want to field the idea to other people who have maybe got good ideas too.
I am looking at using AG parts currently, 1 3/8 6tooth splined shafts with u-joints, the hubs will be 4x4 steel trailer hubs, which I should be able to weld straight to the splined shafting with a little grinding/big drill bit drilling. I will make my own A-arms, bearings will be put in by welding tubing to the bearing points of the spline shafts to give even weight distribution, and using a spline shaft adapter welded to tubing to make a slip sleeve over the splined shaft. 4 u-joints and 6 bearings, some welding and I think I'll have it.
cheaper version uses 1.25" 3/16" square tube and 1.75" 3/16" wall tube for the slip shaft, this is much like the budget drive shaft used on 4x4's. I have to admit this is a tempting solution, and it would be buckets cheaper, problem is it isn't nearly as strong (though probably way more than enough, and requires alot of grease and may click/clank as it isn't as tight as the fit (but may last longer for that reason, grit could ruin the other idea, I'm not sure.)
it will cost for new parts around $250 cheap way 400 dollars the expensive way, hence why I am asking before I spend.
also under consideration, using a ford escort front end, with two short side CV axles, but the CV axles alone will be $300 and that doesnt get me even close to done. this is a bit too costly to be realistic.
