I just recieved this from the builder/seller:
"Hey Chris,
Thanks for the interest. Yes, I know your website and it did help me get started. The go kart was designed and built by myself as a proof of concept. I am a recent mechanical engineering graduate and currently enrolled with graduate studies. This project took about 3-4 summers to complete on a hobby basis, from experimenting with wooden frames and lawnmower engines to what the product is today.
The rear independent suspension is indeed unique. Having a differential drive with CV joints is the universal standard for such suspension systems, yet none were used due to cost and weight considerations. To maintain sprocket alignment, there were two main things to minimize. First, it's the track change (distance between wheel and chassis) when hitting a bump. This is minimized by having the longest links possible. Second, the angle difference between chassis roll and wheel camber during a turn. This is minimized when the links are level to the ground when a person sits in the kart (done by adjusting spring preload). Carroll Smith's "TUNE TO WIN" explains this very well. For the current setup, a maximum chassis roll of 2 degrees including bump conditions will result in sprocket alignment within about 0.7 degrees. Under the same conditions, track change may be up to 1/4in. These maximum limits were found to be satisfactory at the current sprocket-to-sprocket separation for a #35 chain. Other factors to consider include linkage deformations, vibration and toe-in compromises.
Doing stuff yourself is always insightful, but it also rationalizes some of the magic and awe around it!
Thanks again,
Dmitry"
I asked him for more info, and even invited him to join. I'd like to see more. The whole seat thing is peanuts- easy fix. But I am dying to get a better look at the suspension!
