Intake for 22mm Mikuni on a Hemi Predator
Kentucky Boy
Bowling Green, KY
Well how about this for you length lovers.
What you're lookin at there is a 10" unit. Going on my Predator Hemi;)
Kentucky Boy
Bowling Green, KY
I found that on e-blow. $14. I thought it was cool and different plus it makes a cool noise while the motor's running. They have one with the carbon fiber look also.
Here it is. I searched for 38mm (1.5") red air filter.
Jfive
Great falls Montana
started to make mine last night. Should work.
Finished it tonight. Need to make another header and I can try it out.
That cool looking...
I had made a carb adapter for my bike... One thing I had to make sure of...the flanges need to be flat... It leaned out the mix...
The welding warped it a fare amount... Check with a straight edge, grind or sand off the high spots.
Jfive
Great falls Montana
I put it on the grindstone to flatten after welding. Might use high tack on gasket the head side I worry more cause the carb seals with an o ring. Might have to use sand paper on a flat surface if it's not flat enough. It's not as nice as the billet ones but total cost was a few buck for fancy 6mm studs.
Gonna try and get it going Monday I guess. Ran out of time
Kentucky Boy
Bowling Green, KY
That looks good man. Should run great with the carb. Might need bigger jets in it though. Someone asked about the sound from my air filter...it's sounds like air being sucked in.
