Installing the azusa kill-switch to a 6.5 harbor freight engine?
anderkart
Surprise Arizona USA
See where the black and yellow wire join together at that plug on your engine? Simply connect your kill switches wire to those 2.
Also, your kill switch needs to pick up its ground source from where you've got it clamped on your kart... So make sure there's no rust or paint causing a poor ground connection between the kill switches mounting bracket and your kart. Otherwise, the kill switch wont shut your engine off, it'll just shock you when you push the button.
