inspecting engine prior to purchase
mr.matt
Houston, Tx
Looking into buying a gx390 for my build, found one cheap for 70 bucks that is said to run good but smoke a litlle. I want to pick this up but don't want to pick a crap engine sooooooooo is there anything I should look out for? Like signs that make a engine useless, or pieced together or something.
I'm pretty new to small engines, but have tinkered with cars forever. I want to build a pretty badass cart, I work as a welder so building a frame wouldn't be too difficult, just the engine I don't want to have to spend the money twice you know?? So any help or advice or whatever to help me out would be greatly appreciated
kendelrk
redneck engineer
westland michigan
make sure shaft is correct for app., make sure governor linkage is correct and working, and make sure carb gaskets are intact. also check oil level
matman55
I dont have a camera!!
Mims FL
hello matt and welcome to the fourm.i have 3 techniques for looking at engines(online)
1. as you metioned i look to see if they just put the engine together for show.A good example would be "what was this guy thinking" thread in of topic fun. it takes a good eye to spot stuff like this so always be vigialant.
2. ask the person LOADS of questions that could possibly catch someone in a lie.and look for responses such as "yeah the engine runs ,I can turn the flywheel and the piston moves"
3DEAL LOCALY.if at all possibly deal localy to prevent scam and fruad.a new idea ive recently used is vidio.ask the seller to send or post a vid of the engine runing.ask him to film the following process
Keep the camera fixed and focused on the engine at all times
1. film the startup process
2. film the engine runing for a period no shorter than 5 minutes
3. shutdown the engine and film how to do it.
This not only provides proof that it runs but its a little bit of a instuction(for the novice)on how to work the engine.
Hope i helped! -Matman
An added note to the above: Before starting check to see that the engine is cold. a worn motor will blow smoke when it's cold but not so much once it warms up (everything expands when heated). If a seller is aware of the they may "preheat" the engine before you get there (the same as they wouold with a car).
If you can, take a compression tester and see if it has compression. If you don't have a tester, take the spark plug out, put you finger over the hole and pull the starter. Your finger should be blown off.
Check to see if the engine has spark. Take plug out, put the spark back in the boot, hold it against something metal (like the engine block) and pull the starter. You should see a spark at the end of the plug. You could also just hold the end of the plug, but you will get a shock.
Just to clarify; he means your finger will be blown off the plug hole, not off your hand :roflol:
r_chez_08
Should be in the shop...
Cornwall, UK
Make sure it has an air filter. For $70 you can't really go wrong with a genuine Honda.
Are you up for rebuilding it? It probably just needs rings and possibly a few passes with a $25 flex hone. Whilst you have the head off, relap the valves. Since to do this you will need the rod off, you can check the condition of the rod and see if that needs replacing.
But if it runs, $70 is great.
mr.matt
Houston, Tx
Awesome, thanks for all the quick replies. Hopefully I will be able to go pick this engine up soon an begin my build. I've always been unsure of deals that are too good to be true, just hoping this wasn't one, but the way it seems is that if it runs the engine must be good? I don't mind rebuilding, an was gonna take apart just to mild port an polish an inspect while there.
While I say my build is starting, I still meed to go get me a welder so I don't have to do all the welding at work, plus some material for a frame, or a cheap one to modify
Lol, I was gonna say, if my finger should get blown of on the compression stroke of the engine, how many old school engine builders have one finger left, "no, I'm saving this one for the right engine" lol
A good policy. My mother always used to say, "If something seems too good to be true, it probably is".
That said, I'd be all over a genuine GX for $70. So long as it's mechanically intact, everything else is do-able.
