info!!
fatal
whats up guys?well i bought a lifan 15hp motor for my kids yerf dog go kart and i wanted to know if going just chain without a jachshaft is ok?i wont be ridding on mudd or nothing harsh just the streets and gravel in case it mattered.and if its ok what chain size may i need for the stock rear axel sproket?
fatal
tire size are 18x9.50-8 kart is about 200 pounds and me witha kid is about another 200
Then there's absolutely no way you're going to be able to do it without a jackshaft of one type or another. Have you got a clutch, or a CVT?
fatal
i have the stock rear driver for the 6.5hp motor it had i bought a series 40 shaft drive.i try to fit it or mock it up but the plate the jackshaft sits on makes the engine sit too high.also engine mount is wider.and since i need the jackshaft can i mod the one i have by putting a sprocket in replacement of the diver??
