Info gathering for first kart...
heatmizr
Charlotte NC
Good day to all from heatmizr, aka Todd...
I've just begun browsing and gathering some basic ideas. I suppose I got started when I scarfed an electric motor out of my neighbor's electric mower who's controls crapped out. I wanted to see if it is big enough to drive a small kart for my sons. They are only 1 & 3 so far, so I have plenty of time to think ahead.
I looked up a similar mower online to estimate the specs and I believe it is a 36v, 50amp motor, which I calculate to be 1800w. I hope to keep this kart small, and geared down for limited speed, so from my limited browsing I think this should be sufficient.
One thought I had was to build the kart a bit bigger so that we can share - maybe with removable interchangeable seats that I can swap in to fit either them or me. With that in mind I may power it with only 2x12v batteries at first, with the option to add a third battery if I end up with something that I want to drive too.
For now, I am just gathering info, ideas, and the costs involved, and looking for a way to economize on this first kart while gathering experience. I am eager to learn more about alternative sources for controllers, throttles, stock and other parts as I don't have dedicated funds for this (accountant wife).
I'll be at a crossroads soon methinks; either looking for a cheap used frame/completed kart to build on, or getting serious and purchasing a welder for a more homegrown approach! I don't have many fabrication tools so this approach while far more fun might get me in trouble.
Comments welcome...
Todd Glasier in Charlotte
heatmizr
Charlotte NC
Thank you sir; yes that is the first post I happened to see, and very informative.
What do you think of my motor selection? It was free!
I like the idea of "over-volting" a motor. However, using a 36v motor, that's a lot of batteries.
Since I don't think I want to carry 3-4 deep cycle 12v batteries around (heavy), I am toying with the idea of using motorcycle batteries if the kart is small enough. They are also 12v. Maybe 2 or 3 of them will give me enough run time.
There was no mention of "under-volting" the motor. I assume it won't hurt the motor, but just decrease performance; unlike some electronics that need proper voltage to perform - not too much or too little.
You will find that there are very few electric kart enthusiasts here, that would explain why you haven't had many responses. Don't be discouraged, start a thread in the "electric projects" section, it should get a bit more attention there...
Welcome to the forum
