frederic
The Junk Man
My son is currently four, and most disappointed he no longer fits comfortably in the electric toy car I made him a couple of years ago. Other than the tires which I purchased 50% at my local Harbor Freight store and the 300W scooter motor, all of the other components were made from junk I had lying around or cut-offs from other projects.
Here is a YouTube video of my son's first drive in March 2008 when he was three. Pretty much engineered on the fly, lots of glue and reworking, and the body leaves a lot to be desired but to be honest I expected him to kiss one of the many big trees we have and destroy it. He proved me wrong ;-)
Youtube Video: Homemade Electric Toy Car
Anyway, we're about to embark on a much larger vehicle, able to seat at least two children his age and a bit older, and of course that introduces lots of variables as far as sizing. My son also "demands" that it looks like Daddy's truck, an F350 crewcab.
I'm starting to collect parts and scrap as I did for the above project but one of the things I will be building into this is an independent rear suspension, preferably with the differential mounted on the chassis and the half-shafts attached with CV's or u-jounts.
I thought I was being clever and when my neighbor's riding mower's rear transaxle died I offered to do the labor in switching out for the new one that he bought, in exchange I could take the old rear for "experimental purposes". All i wanted to do was saw down the housing and see how close to the differential I could get, i.e. narrowing it. This unfortunately didn't work out as planned so I had to abandon that idea for the time being.
So I'm curious if any of you have considered, and possibly sourced inexpensive parts to build an independent rear suspension, and if so, what did you use for a differential?
While I have all the tools to make beveled gears and the necessary carrier, my machining skills are still "entry level" and I would expect to make about 400 sets of useless gears before getting things right enough to be reliable.
This will be directly driven by an electric motor of unknown size, as I have several choices and will select which motor based on my completing the chassis and tossing it on a pair of bathroom scales.
I'm not in a positon to buy an ATV differential for several hundred dollars, but maybe a used one would be a good choice if I could narrow it down?
Any comments, ideas or eyepokes would be welcomed. Thanks.
Frederic
Frederic
