in theory, how fast will i go with a 7.2:1 ratio?
kartingizm
Murray Hardrive Gokart
in theory, how fast will i go with a 7.2 ratio?
i got a 7.2 ratio and im wondering on average how fast am i gonna go???
specs:
6.5 hf engine at 3600rpm
#40 chain
15in tires at rear, 13in at front
250 - 300 lb kart.
im about 180lb.
and if you need this info
10t clutch to a 24t then from 12t to a 36t axle.
r_chez_08
Should be in the shop...
Cornwall, UK
In theory you could go 22mph.
However your tyres may be slightly larger/ smaller, your engine may rev slightly lower/ higher and you have friction losses from tyre slip etc.
I would estimate 19mph.
JH Pinoy
I have the exact same question too. How fast will it go if my go kart had:
-18" rear tires
-6.5 HF engine @ 3600
-6:1 ratio 60 t on the rear and 10 on the clutch
