In search of a motor
jwh495
Used 6.0 H.P. Tecumseh Powersport
I Didn't Know If You Had Found An Engine Or Not, I Took This Off Of A Large Murray Yardkat Gokart And Put A Larger Engine On It, I Put A Kit In The Carb., New Primer Bulb, New Air Filter, And Spark Plug, I Bought This Gokart For My Grandson, And I Haven't Ran The Engine Enough To Know A Lot About It, But I Ran It Down The Road Before I Took The Engine Off And It Started, Ran, And Sounded Good, Seems To Have Good Power, Still Has The Governor On It, I'll Take $100 For It Plus Actual Shipping, I Can E-Mail You A Picture If You Want To See It, Or Would Trade For A Good Battery Charger/ Jump Starter In Good Cond., Roll Around Or Benchtop Model.
mr fixer
if you have a local flea market sometimes you can get a good used one. i picked up a 6.5 for twenty dollars. with the clutch.
OFFROADER
Columbus GA
I've got an 2006 tecumseh power sport 6.5hp i took off my Carter to do a 16hp clone swap. the motor will run however the carb on it needs to either be replaced or rebuilt as it doesnt want to idle. The block and everything else is in great shape. the motor itself doesnt leak. block is nice and clean. just the carb doesnt want to work. think the float is shot. Im trying to get rid of it for $40. Id recomend just going ahead and getting an aftermarket carb for it honestly. But if you or anyone else is interested just shoot me a message ill be glad to try to work something out. Ill also throw in the Comet 30 series driven thats on it for an extra $10. Its just the driven but these things are just about impossible to find since comet went out of business. its in excelent working condition.
309antonios
Gorham, Maine
I might have just what you are looking for. I've a a darn strong motor, just needs needs crankshaft, unless you can fit a clutch onto the shaft.
It's and B&S 9.5Hp Vangaurd. Strong, very little use. It came off a generator that crapped its pants, motor is good. Just has the goofy tappered shaft for the generator and no gas tank. Pictures upon request. 150$?
Let me know!
