In over my head already
1stTimeKart
Utah
Background: After riding around on my quad (scrambler 400 2-stroke) and watching buggy videos my son is hooked on go karts/buggies. He told his kindergarten teacher that he wants to "race across the desert" when he grows up. He then began drawing pictures of him racing across the desert and would show me his "youtubes" of buggies/utvs in the desert he found when I would get home from work. So, long story short I sold the Scrambler picked up an old Tomberlin 150r frame and a Rupp TR440 engine and set out to build a little off road kart for us to enjoy together.
What I've done: Stripped all the paint and tons of rust, primed and painted, new shocks in the rear, fixed front suspension/steering, welded new area for engine mount, put tubes in tires, and have the brakes pretty much figured out (just waiting on some new lines).
I'm Stuck: When I bought the frame the guy said he was going to put the TR440 in the kart and he gave it to me pretty inexpensively (i thought). I knew it was a 2 stroke snowmobile engine and air cooled so I thought I could figure out something (should have done research). I'm now to the point that I need to figure out the mount, and drive and I think I'm in over my head. I haven't been able to find much information about the engine so I am not sure the best coarse to pursue:
1. Find a snowmobile clutch that will fit this and replace the sprocket on the axel for a belt drive setup
2. Find some way to mount a chain clutch to the existing engine drive (will that work on a snowmobile engine?). All the clutches I've looked at seem to be rated for like 5-10 hp engines.
3. Try and sell this engine and go for a more traditional engine (predator maybe) with more documentation that I have a hope of understanding.
We live in high desert and its pretty hilly so I suspect I'll need a little larger engine with some more torque. Any hints, opinions, or no-how really appreciated. Pictures attached
KartFab
Dallas, TX
check this out for torque converters, ebay, bmikarts, and gopowersports are the top three go kart parts sources.
http://www.hoffcocomet.com/EpiphanyWeb/flexpage.aspx?ID=75
also, not so sure about shaft, but it looks tapered.
You can and should run the torque converter to a jackshaft, then the jackshaft sprocket to chain and axle sprocket.
That engine is pretty big, so think about safety. Might not want to have a kid ride it until he is experienced with cars/proper safety equipment is there.
If you do decide to get a different engine, you could get a very popular predator 420 cc engine, and the 40 series torque converter. With the large tires that the crossfire has, you would need to gear low, so go for a large axle sprocket and a small jackshaft sprocket. With the 420cc, a 9t jackshaft sprocket and 60-72 axle sprocket would be just fine. 420p chain/sprockets.
You wouldn't want to gear it for more than 40 mph with an industrial engine though.
Its totally up to you, but that snowmobile engine would probably be a lot more fun (even though it would require more effort).
Also, I have a crossfire frame, and am wondering where you got parts for it. e.g. bearings, front shocks etc. I would think the lines are universal, but some stuff is proprietary right? most parts I have found are pretty pricy.
1stTimeKart
Utah
Thanks for the response and thanks for the youtube channel (been watching and figuring things out).
Yep. Kid is for sure passenger for a while.
You are correct, it takes a second look even in person, but it is slightly tapered and not keyed just threads on the inside. If I go down the road with the snowmobile engine are those torque converters standard enough that it will mate up to the drive output from the engine? Its already tight back there with that engine so I am a little worried about how to work out the spacing with adding a torque converter and jackshaft. I guess what you're saying though is no matter the engine I'll need a torque converter for the size of machine and tires? not just a clutch?
Crossfire: The tie rod ends were messed up so I replaced them here: http://www.buggydepot.com/model/15/9/tomberlin-crossfire-150r-front-steering-parts.html. The bearings were a common enough size that I actually found them at a CAL Ranch store. The front suspension was ok other than the bushings were trashed. I went down to an autoparts store and found some bushings off the shelf that were close enough (I think they were Chevy Truck) that I got them in the shocks with a vice grip and and then just trimmed the excess rubber that hung out on the edges. I am still on the lookout for some front shocks that are in better shape, but the ones on it are ok for now. Anything else?
KartFab
Dallas, TX
Yeah, the torque converter is pretty much the way to go when off-roading, otherwise you are wasting the horsepower of the engine. I'm not too experienced with 2 strokes, so I cant offer any good advice there (they are fast and fun!).
Thanks for the help with parts. I was hoping you found a place to get shocks as that is the one thing I think I will need to replace.
