improving victas
mattbrown98
Queensland
just a few basic things i have done to my 125cc victa engine for my go kart any opinions or tips
i have done some basic porting made the intake bigger cleaned up the exhaust and made the transfers bigger i havent changed the port timings though
i have also made an exhaust flange to make a bolt on exhaust systme
ak99
Queensland, Australia
Are you going to stick with the stock carb ( I think you mentioned previously you have a G3) or are you going to use a different one?
By the way, I finally got to have a look through my boxes of bits, the spare crankcases I have are for the old 125's ( Toecutter style). I do have a newer complete 125 but I have something in mind for that..
Cheers
mattbrown98
Queensland
i got the crank case issue sorted im using the stock carb for now untill i can find somthing better ive got it runing found an idustrial 24inch cut victa with a 125 on it might have the high comp head on it i hope ill try put up some photos of the modified barrel that i ported
mattbrown98
Queensland
dont know if the photos worked
sideways
Unfinished projects king.
Perth, Western Australia
Cool, I've got a barrel ported into the crankcase like that. I always wondered how it'd go, I never liked how 160s transfer through those little windows in the piston, obviously 125s are a bit different.
I've never seen a 24" with a 125, nor have I heard of a 125 squish band head.
FWIW the factory squish band head for a 160 is part number EN72142A.
ak99
I assume you have notched out the crankcase to match the transfer ports on the cylinder.
Matt, I have an interesting article here about race prepping the 125cc, I came across it when searching for info. It's based on the 1950's 125cc but the info is still relevant for later models.
Happy to email it - not sure if a PDF can be posted here.
This is the carb I bought for mine, also bought the accelerator cable.
mattbrown98
Queensland
yeah sorry about the **** photos i have ran it with the modified barrel and it is definatly alot more bitey and faster response i will take some photos of the whole engine today
ak99 that article sounds pretty interesting
that 24 inch cut mower difinatly has a 125 on it maby someone swaped engines or somthing
i hope to get the cart finnished some time after xmas need to order a new set of sprockets
cheers matt
mattbrown98
Queensland
some photos of the victa for my kart
the 24 inch mower with a victa 125
and the go kart
ak99
The mower looks like a super 600, they came with the 160cc.
At least you now have another 125cc.
The kart looks like a good project too.
If you send me a pm with your email address I will send the article.
Cheers
mattbrown98
Queensland
cheers the go kart is a slight side project my dad and i brought my first car the other day a 1966 xp falcon and i havnt got much money as it is so im working on the car first
also on the kart when i get back around to it im going direct drive 10 tooth sprocket on the front mounted on one of the blade bosses for a victa and a 60 tooth rear is it going to be any good suggestions i just dont have enough money to buy an adapter for a cent clutch
ak99
an XP - I like the sound of that!! ( I'm a Ford guy, Falcons in particular)
Just a thought, the other 125cc you have on the mower, does it have a belt drive running the blade disc?
If it does, then it would be worthwhile checking the drive end of the crank in that engine. I'm pretty sure the engines that had a v pulley were equipped with a keyed crankshaft instead of the taper. The 125cc on your mower may have come from a tilt a cut edger and they also ran a belt drive.
This would eliminate the need for the adaptor - the clutch is the cheaper part out of the two.
Cheers
mattbrown98
Queensland
the old falcon is a beast only a 170 persuit 3 speed manual colum shift ford aall the way :thumbsup:
and ill have a look at that other victa tomorrow if that is the case il be verry happy if not oh well but thanks very much for the advise :thumbsup: the best part about the 125 ive done up was it had the 20 mm crank instead of the 17mm
i have been reading the two stroke tuners hand book it is an awsome read lots of good info
what if i made a belt tensioner drive a jack shaft then the sprocket assembaly that would be pretty cool the chances of it workin i dont know but i could try
sideways
Cheers
Mine just had a pulley with the taper in it. 3.5" diameter A section IIRC. My parts manual shows the some P/N for the crank as normal mowers, it' show's there's a few different sized pulleys with the taper too.
I can post the part numbers if you like. Unfortunately there doesn't seem to be a part number for the 5/8" keyed crank. The only crank variation is one that just has the tapered section with a threaded hole through it. I've never seen one of those before!
Matts isn't the original motor anyway. Still could be lucky though. :)
mattbrown98
Queensland
ill probaly just run the a sprocket drive set up if all else fails and if i have a completly stock engine and a beefed up engine i can test the kart with a stock engine and the with the beefed up engine
mattbrown98
Queensland
few more mods done today on carbie mad a new throttle shaft to piss of the little plastic gears inside the carb
mattbrown98
Queensland
new question could you use a victa 160cc bottom end one with a aloy con rod and nedle bearing big and little end and put the 125 piston on it and a 125 bore im not sure if it would work ???
ak99
The 125 and 160 run 2 different size gudgeon pins (125 is smaller in diameter)
I guess it is possible, but you would need to source a caged roller bearing to suit the 125 gudgeon pin and 160 conrod.
mattbrown98
Queensland
could you make the 160 gudgeon pin fit the 125 by machiening the 125 pistons gudgeon pin hole larger or is it not worth the time and effort ? will the bronze bush little end hold up at high revs though
