mindymogul
Mistress of Destruction
So something is happening that I can't really figure out and it's honestly getting to me. I have this old stock 212 that I just re-gasketed. Put everything back together, let it run for about 5mins and POP! The ceramic core for the park plug goes flying out with the wire cap and engine turns to a stop. Replaced the plug, and go to pull it over and it's acting like it's hyrdolocking on the compression stroke, but it's not. I drained ALL fluids bone dry, turn it over and it does the same thing. All gaps, adjustments, and torque specs are to spec. It turns fine without the plug, turns fine in reverse, and has about 110psi but it has seems like it has ZERO vacuum on the downstroke. I genuinely can't figure it out.
