I have effectively taken all the parts from my Peerless 700 tranny, thrown them up in the air, and put 'em in where they landed...
Okay- here it is. I started with an 075 model 3 speed for my race mower build. I yanked all the gears out of it, and a Peerless 800, and calculated all my available ratios.
I decided on four ratios- 9:1 for transporting the tractor at low speed, and three available race gears- 3:1, 2.4:1, and 2:1.
I put all these gearsets into the 700, and was ready to call it good, until I did the final assembly. Turns out, Peerless did not want that particular combination of gears. My second gear (3:1) spur gear was interfering with the input bevel gear, which rides just below it. DANG!
Since I'm stubborn as heck, I started tinkering. My first thought was to clearance the gear a bit with my grinder. Nope- Don't wanna weaken anything. Second thought- Let's reverse the order of all gearsets. Nope- 2 problems with that working out (detail unnecessary). I could install the 7:1 or 4.5:1 gears that would fit there, but that gives me an entirely useless ratio, and a mouse hair worth of extra drag in the tranny. Nope.
I cannot relocate first gear due to a design limitation, and fourth gear HAS to be the last gear, also due to design. So what's a gearhead to do?
Throw the parts in the air...
Stay with me here...
I removed the fifth gear dummy spacer from the countershaft, and installed it in the second gear position.Then, I reinstalled the rest of the gears in sequence. 1, SPACE, 2, 3, 4.
On the mainshaft, it wasn't that easy because of the shift fork operation. After much deliberation, I took the smallest leftover main gear, and installed it in the second position, to act as a spacer that the shift keys could slide through, and reinstalled the rest of the gears in sequence. 1, SPACE, 2, 3, 4.
Now, from back to front, the shift pattern is N,1,N,2,3,4. The second neutral is due to the spacer and dummy gear. If you've been in my Weed Warrior thread, you already know that I'm not interested in more than one Neutral (thanks to removing Reverse) So-
I took an extra spacer, and installed it BEHIND the shift collar, thus blocking the shift collar from going into the original neutral position entirely, locking it out. Now, my shift pattern resembles a bike- 1,N,2,3,4. Remember that 1 is very low (9:1) and 2,3,4 are 3:1, 2.4:1, and 2:1 respectively, giving me some close ratio choices.
Originally, this was a 3 speed tranny! 9:1, 4.5:1, and 3:1, as R,N,1,2,3, and now it's a 4-speed. 9:1, 3:1, 2.4:1, 2:1, as 1,N,2,3,4.
If necessity is the mother of invention, then Stubbornness iss the mother of problemsolving.
Ok. I am officially not smart enough to understand anything past the 2nd sentence...Sounds super exciting tho
