Im a new go kart builder
Dejean91
OK so I got a Murray frame and put a Briggs and Stratton 18 HP v twin van guard on it and everything works fine except when I try to go up a hill it will not not make it.. it doesn't die it just won't go up anything.it's Not even a big hill. Plz help
Did you try adding wheels and tires to your engine and frame?
jk
How big are your tires? Diameter please.
How many teeth on your clutch? Is it 8, 10, 12, ....?
How many teeth on the Rear sprocket? Is it 40, 48, 54, 60, 72,... ?
That v-twin should be able to get you up a little hill, even with big ole tires. I'm curious to see what the gear ratio is, but think it might be more than just the gear ratio.
KartFab
Dallas, TX
Clutch is 13 and sprocket is 60
when you say clutch, do you mean centrifugal clutch? So basically a $1,000 engine with a $50 clutch? You will be burning that out if it is any sort of centrifugal clutch.
Get a 40 series torque converter.:thumbsup:
If you are cheap and handy, you can fab up a jackshaft with pillow block bearings and some steel plate. 10t jackshaft sprocket.
If you are not handy, but have money you can get the 40 series with backplate that bolts right up.
You would probably have a better experience with a predator 212cc and 30 series than that giant engine with a centrifugal clutch.
