idk ct200u wont start after mods
caseysct200u
burn them fk!ng tires to the rim!!
Could be stuck in the carb. Even the slightest bit of dissimilar corrosion or oxidation between brass and aluminum can "weld" the thing in place. Brass gets "verdigris" and Aluminum gets that chalky degradation. Combine that with an ill-fitting, wrong size screwdriver and voila.
The whole bike may be fairly new, how new I don't know, but it does not take too long. The process is quickened with that dang ol' ethanol blended gasoline....
alright ill see if thats the case
We danced over the topic of screwdrivers but the screwdriver 🪛 has to have a narrow enough shank to fit into the hole where the jet is, and having the correct “bit” size on the tip is also important. Otherwise it is very easy to accidentally twist the screwdriver out of the slot in the brass jet and mangle it up good. Brass is much softer than the screwdriver and you can end up hogging-out (highly technical term!) the brass slot to where the screwdriver can’t do its job.
The best screwdrivers are the ones with “hollow ground” tips.
You nailed it. Tip width, thickness, and shank diameter are very important when that jet wants to play stubborn. Easy to mangle it. Just like you described.
caseysct200u
ah ok I'll put that on my list of tools to buy
caseysct200u
hey guys im back just wanted to let yall know that my stupid ahh admin blocked this site but hey i found a way around see yall this summer wien i get back on peice out
caseysct200u
yo whats good guys sooo i got a girlfrend and um is gettin me in some bad things if you know you know and um yea just wanted to et yall know oh yea and shese into dirtbikes
trust me you dont wana be in the same sh!tty school im in it SUCKS
(somehow worse than my ex)
the kids at my school are crazy they also got vape dectors (like wtf if i wana screw up my life just let me do it) and also we got girls lokin like s1uts
I’m all for vape detectors and s1uts!
🤣 :cheers2:cheers brother
You got that minibike running yet?
This could be you this summer....
klad
I recommend you just get a nibbi carb and jet kit everyone I've bought and installed fired up first try. Don't go bigger the 26mm.
At this point, I am afraid we are....
He’s just a young buck with too many choices and not enough loose change.
A Nibbi would be nice, are you willing to donate one for the cause? 🤑
klad
What was the original jet and what was the new jet look for a small number on top.or the side and same for the pilot jet 🤔 also what's your elevation if you know
klad
Also while it's running try and ride it up and down the block and hit the kill switch while it's going dont let it idel it will mess up your readings pull the plug out post a picture. If you can't ride it just idel it for like 5min and then pull the plug black is too rich white is lean. One last thing is pop the fuel line if it has flow likely it does but still wanna confirm
