idk ct200u wont start after mods
caseysct200u
burn them fk!ng tires to the rim!!
Could be stuck in the carb. Even the slightest bit of dissimilar corrosion or oxidation between brass and aluminum can "weld" the thing in place. Brass gets "verdigris" and Aluminum gets that chalky degradation. Combine that with an ill-fitting, wrong size screwdriver and voila.
The whole bike may be fairly new, how new I don't know, but it does not take too long. The process is quickened with that dang ol' ethanol blended gasoline....
alright ill see if thats the case
We danced over the topic of screwdrivers but the screwdriver 🪛 has to have a narrow enough shank to fit into the hole where the jet is, and having the correct “bit” size on the tip is also important. Otherwise it is very easy to accidentally twist the screwdriver out of the slot in the brass jet and mangle it up good. Brass is much softer than the screwdriver and you can end up hogging-out (highly technical term!) the brass slot to where the screwdriver can’t do its job.
The best screwdrivers are the ones with “hollow ground” tips.
You nailed it. Tip width, thickness, and shank diameter are very important when that jet wants to play stubborn. Easy to mangle it. Just like you described.
caseysct200u
ah ok I'll put that on my list of tools to buy
caseysct200u
hey guys im back just wanted to let yall know that my stupid ahh admin blocked this site but hey i found a way around see yall this summer wien i get back on peice out
caseysct200u
yo whats good guys sooo i got a girlfrend and um is gettin me in some bad things if you know you know and um yea just wanted to et yall know oh yea and shese into dirtbikes
caseysct200u
trust me you dont wana be in the same sh!tty school im in it SUCKS
(somehow worse than my ex)
caseysct200u
the kids at my school are crazy they also got vape dectors (like wtf if i wana screw up my life just let me do it) and also we got girls lokin like s1uts
You got that minibike running yet?
This could be you this summer....
