Identify this briggs carb?
B.M.800
TheBeal.
Central PA
Hey guys, anyone here Identify this carb? I could use a partslist.
Dont let the manifold fool you, its from a vert shaft 10hp Tec.
I was cleaning it out and put the blow gun to it and launched a part out of where the needle valve goes... I have no idea what it was. Its lost and gone forever. :ack2:
When I hooked up the fuel line, gas pored out of the thing.
Same thing happened with the tec carb so maybe I lost the part for it too... but I didnt think there was anything in there? :huh:
Thanks!
Look for numbers on there somewhere. If that fails, take the numbers off the engine to reference the carb parts.
Sounds like you blew the seat out- that's the part that the needle seals against.
B.M.800
TheBeal.
Central PA
I would have used the engine, except I have no Idea where it came from. I didnt even realize it was a briggs untill I took it apart and saw the little briggs logo thing on the float.
I suppose trying to cleverly rig a something up on there is pretty much hopeless...
Im hoping the other Tec carb still has a good seat, assuming thats what it needs...
