Identify a Coyote
jlnel
MA
I picked up a used Coyote kart and would like to know what model it is, the guy told me its the race one... Lol.
I dont see any markings but its kinda dirty, ill get it up on the table and look closer, can anyone point to where marking should be? Thanks.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
jlnel
MA
I just sent pics to Coyote so i hope They can identify.
Thanks, it does look pretty cool but the ground clearance may be to low for me. I may need to trade out for an off road one!!
firemanjim
Just kartin' around....
Houston Texas
:idea2: why not try a little bit taller tire?
jlnel
MA
I know nothing about the kart yet. That was one idea i thought may wirk. I will have to get this thing up on a table and write down all the details. Id love to get 2-3" more ground clearance. Looks to be all set up for oval or circle track, so i need to get it back to a " neutral" stance i think.
I have been told this is a great foundation for a shifter kart, true??
Lot to learn.. Lot to learn!
firemanjim
Houston Texas
Yes, that IS a chassis that readily accepts a "shifter engine".... but you can put a m/c-atv engine on just about any kart.....
Tell us the tire size, tooth count on drive sprocket,tooth count on driven (axle) sprocket.....
jlnel
MA
Ok, its at work so ill try and get all needed info and post. Thanks for all the help.
jlnel
MA
sprockets are 12, 66. chain is #35. tires I think are, 11".
i have to go with a cheap clutch for now, had some bills pop up.
firemanjim
Houston Texas
Well , if you have 11" tall tires..... with a ratio of 5.5:1..... You get 21mph @ 3600rpm ,....., with no gov ,hitting 5000 rpm, you will hit 30mph.....
firemanjim
Houston Texas
Well, with a 14" tall.tire @4800rpm with a 5:1 (12~60) you hit 40mph, but your take off suffers a little....
